hollow fiber membrane CFD
Old   March 17, 2009, 00:57
Default hollow fiber membrane CFD
Dong Fu
phxfudong is on a distinguished road
Hi all, I am trying to model a hollow fiber membrane as a pressure jump surface
here is my BCs:
=======pressure outlet===================
========porous jump====================
pressure inlet (water) pressure outlet
=======pressure oulet====================
I set the porous jump permeability as 1.7E-16 m^2 and thickness of 0.278mm .
The inlet pressure is 8.4 psi and outlet pressure is 3.8 psi.
The pressure at the side wall is 0 psi
But the case is always not converge, can anybody help?
Thanks
phxfudong is offline   Reply With Quote
meshing a hollow box waalik FLUENT 3 September 4, 2008 23:10
Continuous Fiber Model sunyafeng FLUENT 0 June 6, 2008 09:24
Incoherent problem table in hollow-fiber spinning Gianni FLUENT 0 April 5, 2008 10:33
how to specify axis in hollow geometry vinayak FLUENT 4 September 1, 2002 10:46
how about the add-on modual "continuous fiber' cfder FLUENT 0 May 23, 2002 03:22
