Installing Fluent on OpenSuse
Old   March 24, 2009, 13:53
Default Installing Fluent on OpenSuse
Ulisses
ulisses is on a distinguished road
I'm trying to install Fluent on OpenSuse but I'm not having success.
Could someone help me?
Thanks a lot
ulisses is offline   Reply With Quote
Old   March 24, 2009, 16:09
irineupetri
irineupetri is on a distinguished road
Thanks a lot
I too have this problem, when I try open the file (Fluent_install) don't open nothing... I want to know, how I open the file (Fluent_install) on linux openSuse 10.3 and install the Softwate Fluent. Is this compatible with Linux openSuse 10.3? What other version of the Linux is compatible with Fluent?
I used the Fluent 12.0.7 and 6.3.26
(Sorry for my English)
irineupetri is offline   Reply With Quote
Old   March 25, 2009, 14:22
pulgarcito is on a distinguished road
Hi to all,
You must run fluent install script in a terminal
sh Fluent-install-script
If you want to install it on /opt or similar directory you need root permissions.
After install, probably you need to install some packages to run fluent or gambit.
If I am not wrong they should be libmotif3 and some libstdc++ libraries.
I installed it under SUSE 10.1 two years ago, and now it is running under perfectly under Debian ETCH.
pulgarcito is offline   Reply With Quote
Old   March 25, 2009, 15:27
Default hardware
nazareno mancinelli
yochule is on a distinguished road
pulgarcito: can you tell me what hardware are you using with suse and debian. i can install both fluent and gambit in a semprom2500+ with ubuntu amd64-8.10 and it run fine. but in a athlon64 x2 i cant install fluent (but gambit run fine).
can you confirm the hardware in your instalation?
gracias
yochule is offline   Reply With Quote
Old   March 25, 2009, 15:42
irineupetri
I installed the Fluent, but I don't achieve open the software. where is the executable of the Fluent? If I to install the Debian I don't need to install any packages? Where I find the packages of the opensuse? I use intel core 2 quad - 64 - I need some help, because I'm a new user of the linux, I'm try move of the windows, because it is vulnerable. Tanks for help
Old   March 26, 2009, 03:36
Hello to all,
I installed fluent and gambit on a amd opteron machines (64 bit) under open suse 10.1 and debian etch.
Some weeks ago i have performed the installation in a intel core2duo machine (ubuntu 8.10 amd64). I think that debian is better due to the lack of suferfluous packages that ubuntu family distributions install on your systems.
If I am not wrong installing libstdc++5 and libmotif3 packages both programs work fine.
Please copy and paste your starting errors and look for on google. Usually after some attmeps you get them running.
Regards
Old   March 26, 2009, 03:47
Hi Irineupetri,
To launch the codes you need to open a terminal and look for your Fluent installation path.
In the installation process, the script tells you where you want to intall fluent programs.
Once you are in Fluent.Inc/bin directour, simply write down ./fluent (dot/fluent). Thats all.
Regards
Old   March 26, 2009, 14:46
irineupetri
When I try run the Fluent show this:
"On Fluent 12.0.7"
linux@linux-qneq:~/ansys_inc/v120> ./fluent
bash: ./fluent: is a directory
"On Fluent 6.3.26"
/home/linux/Fluent.Inc/fluent6.3.26/bin/fluent -r6.3.26
Error: directory /home/linux/Fluent.Inc/fluent6.3.26 does not contain a valid arch.
Set the environment variable FLUENT_ARCH and try again.
but, this file isn't a directory
Why I don't achieve run the fluent in my machine?
Old   March 26, 2009, 19:20
Default linux architecture
nazareno mancinelli
irineupetri- you must to look about your problem. but in my experience, i have the same error message, and i clear up it adding in the .bashrc this lines:
FLUENT_ARCH=lnx86:$FLUENT_ARCH
export FLUENT_ARCH
but this solution is because i was runing in a amd sempron machine. i think you must add something like:
FLUENT_ARCH=lnia64:$FLUENT_ARCH
export FLUENT_ARCH
you can trying to launch fluent in a terminal prompt:
---:~$FLUENT_ARCH=lnia64 fluent
good luck
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Comparing Fluent Time dependent result with Patran venigall FLUENT 0 January 13, 2007 19:30
Installing Fluent on Server CAM FLUENT 0 January 12, 2007 20:20
Run Fluent in batch mode Shengping LUO FLUENT 2 October 24, 2000 05:42
