April 2, 2009, 18:32 |
Polyhedral in parallel
diego flores
Hi , everybody.
I have seeking information about polyhedral meshes. But I was not find it. Could tell me someone if it is possible generate polyhedral meshes in parallel??? Or what is the best way to generate a big model in polyhedral mesh?? Thank you |
April 2, 2009, 19:22 |
I think you must generate a tetrahedra mesh first then convert it into a polyhedra mesh, and if the mesh size is very large you may need a large memory size to handle the conversion.
April 2, 2009, 20:54 |
Polyhedral Mesh
diego flores
Yes, I know all the process for generating the polyhedral mesh. What I want to know is the process to generate amodel in a parallel way, if it is possible!!!! So , if I have a large model how I can convert it to polyhedral in parallel.
April 2, 2009, 22:58 |
I don't think Gambit can generate a mesh in a parallel way, but you can try to see if your conversion can be done in Fluent's parallel mode.
April 2, 2009, 23:31 |
Polyhedral mesh
diego flores
I did the tetrahedral mesh in tgrid, after i export the mesh to fluent 6.3.33, and I tried to convert it in a polyhedrical mesh. all above i tried to do it in a parallel way but it does not work, it fails. So in a only processor fluent cannot do it because the memory is out. that is the reason why i'm asking about the converting to polyhedrical mesh in parallel.
April 3, 2009, 17:56 |
Allan Walsh
This may not help you, but the Fluent 6.3 polyhedral converter seems to have issues. The one in Fluent 12 beta works better, and was able to convert a mesh that 6.3 couldn't on the same machine.
At least in Win-dos, there are some standalone utilities for working with or converting to polyhedral meshes. Perhaps, your friendly Ansys rep. could help you with those. |
Script to Run Parallel Jobs in Rocks Cluster | asaha | OpenFOAM Running, Solving & CFD | 12 | July 4, 2012 22:51 |
HP MPI warning...Distributed parallel processing | Peter | CFX | 10 | May 14, 2011 06:17 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
parallel mode - small problem? | co2 | FLUENT | 2 | June 1, 2004 23:47 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
