Kato-Launder equation
Old   May 1, 2009, 08:47
Default Kato-Launder equation
paaresh
sri31049 is on a distinguished road
hai
I am trying to apply the Kato-Launder k-epsilon turbulence model for my problem. So, i have to modify the production term in the standard k-epsilon model. Is it possible with UDF's? Is it possibule to impliment Kato-Launder model using UDF's? please help me in this try.
thanks in advance for ur suggestions.
sri31049 is offline   Reply With Quote
Old   May 2, 2009, 04:06
Administrator
pete's Avatar
Peter Jones
pete will become famous soon enough
Kato-Launder is already implemented in Fluent. You can turn it on using the text-interface commands (not the gui)
pete is offline   Reply With Quote
Old   May 2, 2009, 05:51
paaresh
dear pete
thankyou so much for your kind reply. i am very happy with your answer.
can you please tell me how can i found the text commands and how to activate this kato-landur equation?
is it availabule in FLUENT 6.2 also?
thanks in advance for your suggestions.
Old   May 3, 2009, 00:59
paaresh
hai peter
thanks for your advice. i enabled the Kato-Launder model with text interface comands. But i dont know where i can see it is really enabled or not?. and in summery it is showing stadard k - epsilon model but it is not showing kato - launder model is enabled or not?
please help me in this problem. i a really tnankful for ur suggestions
sri
Old   May 3, 2009, 05:12
Administrator
pete's Avatar
Peter Jones
Fluent support should be able to help you with the details. To see from the solution if Kato-Launder is active I would advice you to look at the turbulence levels in stagnation regions and in the free-stream. The k-levels in stagnation regions and regions oustside boundary and shear layers should be much lower when you have Kato-Launder active.
Old   May 3, 2009, 06:24
paaresh
hai peter
thanq so munch for ur suggestions. i will follow ur advice.
thank you so much
best regards
sri
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Kato Launder UDF mike laudrap FLUENT 1 February 12, 2008 05:15
Kato and Launder modification subroutine mike laudrap FLUENT 0 January 27, 2008 21:41
continuity equation Rafal Main CFD Forum 4 November 29, 2006 09:27
Diffusion Equation izardy amiruddin Main CFD Forum 2 July 4, 2002 08:14
