Gambit problem -2D
Old   April 8, 2003, 13:05
Default Gambit problem -2D
Manan
Hi
I am developing a 2D geometry in gambit.Its a simple rectangle with inlet and a outlet.I created the geometry,meshed the edges and the face. Inlet and outlet were given BC as mass flow inlet and outflow. I read in manuals that gambit automatically takes other boundaries as wall and continnum type as fluid. However I am not able to export the mesh into fluent.It gives the following message.
" Warn : Continuum Entity fluid.3 does not contain any valid entity and is not written Warn: Boundary Entity mass_flow_inlet.5 does not contain any valid entity and is not written. .....
No entites were found for mesh export Errors were found during export. Export file was not created "
Any advice on this will be helpful.
Old   April 8, 2003, 16:00
Default Re: Gambit problem -2D
Alex Munoz
Hi
I guess you create the mesh the boundary condition but you forgot to select the edge that correspond to it boundary.
try this Do not assign boundary conditions in gambit It will define some for you then check if it can be exported Let me know if it work!
Regards
Alex Munoz
Old   April 8, 2003, 18:15
Manan
Hi Alex
Thanks for your help. Actually I had allocated the boundary conditions properly but did not turn on the a small button for exporting 2D mesh!!!!! anyways the problem got solved.
Manan
Old   February 13, 2015, 08:43
Neha
neharawat23@gmail.com is on a distinguished road
Originally Posted by Manan
;105295
Hi Alex
Manan
HI Manan,
Could you tell me how was your problem solved?...b`coz I am also facing the same problem..
Thanks in ADVANCE....
neharawat23@gmail.com is offline   Reply With Quote
Gambit geometry problem cestrin FLUENT 3 July 4, 2012 02:33
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam Rachid BANNARI (Bannari) OpenFOAM Meshing & Mesh Conversion 25 September 11, 2011 07:58
Gambit installation problem Panos FLUENT 4 March 5, 2009 22:44
Problem meshing with Gambit Adrian FLUENT 8 October 7, 2008 08:39
Startup Problem in Gambit 2.2 with WindowXP Win Win Maw FLUENT 3 January 25, 2006 11:09
