Question regarding Fluent's Turbulent Pipe Flow Problem |
May 15, 2009, 03:33 |
Rep Power: 17 |
I had used FLUENT to resolve the developing flow in a pipe for a pipe Reynolds number of 10,000 on the following meshes: 100x5, 100x20 with uniform spacing in the radial direction.
How do i compare the exit value with the expected value for fully developed flow (e.g., 1/7th profile or your fine mesh results)??? [IMG]file:///X:/Fluent/pipe2/ps1_files/ps1equation.JPG[/IMG] This should be either less than 4 (so that you resolve down into the viscous sublayer) or greater than 30 (where wall functions can accurately compensate for the poorly resolved viscous sublayer). However I got a value between 8 and 12 for the 100x20 mesh. How do i calculate the value of y1+ for each mesh??And how does it help explain the trends in the agreement that i observe?? |
simple pipe flow question | arkur | Main CFD Forum | 0 | June 29, 2008 18:07 |
turbulent pipe flow | John | FLUENT | 2 | August 2, 2005 13:00 |
UDF for fully developed turbulent pipe flow | Maged | FLUENT | 1 | June 11, 2005 10:37 |
turbulent flow in cavity problem using k-w model | khairy | Main CFD Forum | 3 | February 27, 2005 12:12 |
Turbulent steady flow around a circular cylinder | Mirek Kabacinski | FLUENT | 0 | July 23, 2003 18:40 |
