Is boundary layer "a must" in turbulence flow? |
May 25, 2009, 06:06 |
Ping
Rep Power: 17 |
I wonder in modelling a turbulence flow, is constructing a boundary layer before meshing very necessary? Can we still run a turbulence model problem without it?
And if the model is very complex, how are we suppose to calculate for the height of the first row in boundary layer??? |
May 25, 2009, 07:50 |
#2 | |
Rep Power: 16 |
Hi ,Pingaroo I would like to talk with you about this interesting issue.Yes, Ii is necessary to decide which turbulence model shoul be choosed to match our object.As all known, the Navier-Stokes equations is not closed themselves.Therefore, the turbulence model is indispensable. Whether the model is quite complex or simple, the height of the first row is same to calculate before meshing grids.Here, I just ensure this problem.If you wonder knowing how to calculate the ds, I am also glad to discuss it with you . Byron.25th,May. |
May 25, 2009, 08:02 |
Ralf Schmidt
Rep Power: 17 |
Hi!
If you focus your simulation in heat transfer or drag, it is VERY important to have a properly BL treatment. For that, there are basically two types of turbulence modells (RANS): 1 near wall treatment and 2 wall function. For 1. you need to resolve the BL with your mesh down to a value of yplus < 5 (best is yplus about 1). And there should be a number of cells within the BL (something like min. 5, but for good results i would suggest 15-25) For 2. the BL is not resolved and there is a standard log function assumed. Your yplus could be between 30 and 300 (best is about 30). For calculation of the first row in your BL fitting to the desired yplus see: http://www.cfd-online.com/Wiki/Dimen..._wall_distance You don't have to use the BL option in Gambit to resolve the BL with a mesh. You might use any other cell type, as long it is fine enough. BUT, the BL option is a very nice tool and it will result in general in a very good quality mesh. Another hint: if your yplus in the simulation is out of the desired range, you can adapt the yplus in the adapt menu (->adapt->yplus, or adapt-> region) Best wishes! Ralf
CFD - nothing but Colourful Fluid Dynamics |
May 25, 2009, 11:09 |
Ping
Rep Power: 17 |
Hi Byron and Ralf, Thank you for your replies.
So basically boundary layer is a must when we need to focus on drag or heat transfer.... and is it always a good idea to check whether the turbulence model is in the wall yplus range? I know that we can calculate the height of the first row by using flat plates skin friction but it is for a very simple model. So, Byron would you please discuss more about complex model?
CFD - ColourFul Diagram!!! |
To thin boundary layer? | Luk | CFX | 3 | February 27, 2009 03:22 |
transform navier-stokes eq. to euler-eq. | pxyz | Main CFD Forum | 37 | July 7, 2006 08:42 |
Boundary layer flow goes the wrong way | andimb | OpenFOAM Running, Solving & CFD | 2 | March 20, 2006 08:51 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
Wall turbulence, viscosity, boundary layer | Patrick Godon | Main CFD Forum | 1 | November 5, 2003 15:39 |
