The value of velocity
Old   May 25, 2009, 05:54
Default The value of velocity
Jin Chen
swe704 is on a distinguished road
Hi all,
In my case,I provide the uniform (consistent)velocity with the magnitude of 1.5m/s at the inlet surface(the surface consists of several small faces,all them are with the value of 1.5m/s),but when i check the inlet surface again after simulation,i get the value of 1.55m/s(Vectors-velocity-deselect auto range-get the maximum value).Why these two values are not consistent?Does this mean some part in mesh or Fluent is wrong? I do hope i can get some explainations from you.
Thanks in advance.
swe704 is offline   Reply With Quote
Old   May 25, 2009, 08:22
Ralf Schmidt
Ralf Schmidt is on a distinguished road
Hi!
I thing, that little maximum value is due to the velocity profile, that is about to begin to establish.
For checking velocity, use ->report->surface integrals.
Select the areas(s) you are interested in. Use the "area-weighted average" velocity (x,y,z or magnitude)
Ralf
CFD - nothing but Colourful Fluid Dynamics
Ralf Schmidt is offline   Reply With Quote
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 06:10
Velocity Under-relaxation in SIMPLE type methods Matt U. Main CFD Forum 6 July 4, 2005 05:29
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
