May 25, 2009, 15:11 |
Stratified Two Phase Flow
Ravi Kapoor
Rep Power: 17 |
I am an undergraduate and beginner of this software FLUENT and currently working on stratified two-phase simulation in 3d geometry. My problem is that I have a cylindrical pipe and I have to analyse the velocity profile when the flow is fully developed, so I am working on Laminar, steady state conditions. Although, the problem is not realistic but still, this is the beginning step to learn so that later I can solve realistic two phase turbulent flows in pipes. In my case, I know the inlet and outlet pressures and the interface level between the two phases is constant along the length of the pipe. So, I am unable to decide which model should I use - VOF or Eulerian and how to define the boundary and interface conditions. Fluent user manual says that for stratified multiphase flow, we should use VOF model but I am not able to figure out how to define the interface level (which is kept constant) such that there is complete separation of two phases. Please help. Thanks |
May 29, 2009, 05:13 |
Anupam Jain
Rep Power: 17 |
I suggest you to go through the VOF Fluent tutorial. It clearly explains how to model the interface and other details. You need to create a register (region) for a particular phase and patch that region with volume fraction value of 1. Anupam |
eulerian, multiphase, stratified, two phase, vof |
Error in Lax-wendroff with two phase flow | k.baker | Main CFD Forum | 1 | November 24, 2007 04:22 |
Yplus [y+] value for gas solid two phase flow | P.R.Naren | Main CFD Forum | 0 | September 5, 2006 02:04 |
one-fliud formulation twophase flow with phase cha | Dusky.He | Main CFD Forum | 0 | December 30, 2005 10:27 |
How to obtain mass flow rate of one phase | Derek Jing | FLUENT | 1 | May 31, 2002 13:18 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
