Percentile or histograms based on volume or mass, not on elements |
May 26, 2009, 12:00 |
I want to report some statistics about a flow, such as, which percentage of the volume has lower velocities than some value (e.g. 0.5m/s). I see there is a possibility to build histograms and this could be enough. However, they are based on the number of elements, but each element can have different volume so knowing that 50% of elements have velovities inferior to 0.5 m/s is not of help!! Do you know any way to achieve this? I was thinking that if Fluent is not able perhaps some postprocessing software like Tecplot360 would fit my needs (i have never used any before). Thanks in advance |
June 29, 2022, 11:54 |
Johnny Mercurial
Rep Power: 5 |
Hi everyone,
Does someone have a solution to this issue, I would also be interested to know about this feature if it exists. Thanks, Johnny |
June 29, 2022, 12:18 |
Lucky
Rep Power: 66 |
Volume integrals exist. CFD-post even gives the option of including weight functions. If you don't have a weight function in your post-processor, you can simply create one via a custom field function.
Threshold parts also exist. Create thresholds above/below your criteria and then make a report on the part. Solutions exist but but they require a little bit of inside the box thinking. |
Error message: Insufficient Catalogue Size | Paresh Jain | CFX | 32 | February 3, 2021 03:37 |
Volume based refinements in Pro-amm | krish | Siemens | 1 | June 21, 2007 05:39 |
solution still volume based? | Mechiqo | Siemens | 2 | May 22, 2006 08:44 |
code for control volume based finite element metho | yang | Main CFD Forum | 0 | October 18, 2004 03:39 |
control volume based finite element | araz | Main CFD Forum | 1 | November 15, 2003 17:50 |
