June 3, 2009, 05:06 |
wall roughness
Eric
hi!
can anyone tell me how to define wall rougness parameters(Roughness Height and Roughness Constant)? the diameter is 27mm. roughness is 2%. is that to say the Roughness Height is 5.4e-4? thanks! |
June 3, 2009, 12:41 |
mj sharawi
Hi Eric,
I've never heard of something like that, but here is what I would do if I were you (I am not sure if your case is as simple as in my mind): I will try to include the effect of roughness with a "momentum sink" added to the momentum equation. regards, MJ |
June 3, 2009, 21:04 |
#3 | |
Eric
can you explain the meaning "momentum sink"! it is also my first time to hear the "momentum sink"! thanks........... |
June 4, 2009, 05:37 |
mj sharawi
Hi Eric,
Go to: Define => Boundary Conditions. . . , choose your fluid zone. in the window, activate source terms. Then you can add negative source terms in the x-momentum and y-momentum equations (if you are using axi-symmetric, axial and radial momentums). Don't ask me how to calculate them for your case, I don't know , as I said; this was just an idea. Maybe you can refere to the friction factor correlations and find something out. I hope this helps a little. MJ |
June 4, 2009, 14:46 |
mj sharawi
I forgot to say something, if you are not familiar with sources terms, adding a negative source term (which is a sink term) is equivalent to increasing the pressure drop the in the axis of intrest.
Regards, MJ |
June 4, 2009, 20:24 |
#6 | |
Eric
thanks |
June 5, 2009, 00:19 |
tried looking at Fluent Documentations
Sorry if I am asking the obvious, but have you tried looking at Fluent Documentation.? I've found several information on this on the following link to Fluent doc... file:///usr/Fluent.Inc/fluent6.3.26/help/html/ug/node253.htm#33285 Also they make reference to the following book, which have the formulas that you are looking for. T. Cebeci and P. Bradshaw. Momentum Transfer in Boundary Layers. Hemisphere Publishing Corporation, New York, 197 Cheers, Javier |
[Commercial meshers] Fluent3DMeshToFoam | simvun | OpenFOAM Meshing & Mesh Conversion | 50 | January 19, 2020 15:33 |
Assigning Wall Roughness in STAR-CD | Sachin | Siemens | 1 | March 11, 2008 11:24 |
Assigning Wall Roughness in STAR-CD | Sachin Patil | Siemens | 0 | March 6, 2008 03:05 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
