Zones Splitting
Old   June 12, 2009, 13:03
Cool Zones Splitting
Ravi Dodd
ravids is on a distinguished road
Hello All
When I create my mesh in gambit and read it into fluent, somehow my zones get split into further parts. For example, the "default-interior" zone splits in default-interior:012 and default-interior:016. Also, the wall gets split into wall:002 etc., Why does this happen and more importantly, how do I prevent this from happening? Does it mean my gambit meshing is wrong?
Ravi
ravids is offline   Reply With Quote
Old   June 15, 2009, 02:03
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
no, your mesh isn't wrong.
I think you have defined a BC, which enforces Fluent to split your domain.
You can try to merge the faces together, but I assume it will fail (else Fluent wouldn't have separate the faces).
Check your BC, but you can work normally without problem
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
fluent, split, zones
Skipping Zones 1337Hal FLUENT 1 June 27, 2022 09:33
merge zones Domi FLUENT 2 May 3, 2019 13:15
flux splitting emrah Main CFD Forum 3 August 30, 2014 08:53
Flux splitting Dr B.M. Smith (Smith) OpenFOAM Running, Solving & CFD 19 January 9, 2013 04:07
Patch-Different values to different zones Pradeep FLUENT 0 April 26, 2005 08:50
