Fluent VOF Volume of Fluid Realistic Solution Problem
Old   June 3, 2009, 07:04
Default Fluent VOF Volume of Fluid Realistic Solution Problem
wormik is on a distinguished road
Hello all, this is my first post, I hope anybody can help me here.
I want to model a full fuel tank and the fuel movement in a wing, but before that I wanted to learn the aspects of VOF and real-time animation of it.
I have constructed a simple tank model. In it, I have put the water volume in an oblique angle in the bottom part of the tank. Then I have defined the gravity which is -9.8 m/s2 in Z direction. From start, with gravity, the water should move in the tank and settle down a little bit.
Using VOF model and with time-step 0.05 secs, I had 1200 iterations and 1200 .dat files to construct the animation. Since time-step is 0.05 secs, 1200 iterations make 60 secs with 20 solutions (frames) per second.
Then I used TecPlot to construct the animation movie, telling it that "you should use 20 solutions (.dat files) to construct 1 second of animation" With these settings I had 60 sec animation movie. But it does not seem realistic. The flow is so sluggish like it is not water, like it is a lot more thicker fluid. When I speed up the movie like 60 frames per second, it is more realistic. But then the reason why I make this animation comes to my mind. I should determine the exact points in animation that can be trouble for the design. I could not trust the computation of Fluent.
Do you have any similar experience or suggestions regarding this?
Please correct me if I am wrong:
since time-step is 0.05 sec, 20 steps make 1 sec.
I should use 20 frames (.dat files) to construct 1 sec of animation.
1200 steps (.dat files) make 1200 frames and from 20 frames per second I should have a realistic 60 secs movie, which I did not.
Regards
wormik is offline   Reply With Quote
Old   June 12, 2009, 15:30
Default fuel tank slashing
sadrooz
hamed_roozegar is on a distinguished road
this may be useful .
http://rapidshare.com/files/233767574/tank-sloshing.pdf.html
http://dl.free.fr/getfile.pl?file=/MB3v98CX *fuel tank sloshing*
hamed_roozegar is offline   Reply With Quote
Old   June 12, 2009, 15:40
sadrooz
this might be useful
Old   June 21, 2009, 07:04
Thank you so much! I will look into them in detail.
That was the example I have always faced into when I made a google search. Thanks a lot!
animation, real-time, time-step, vof, volume of fluid
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Rev: Can Fluent 6.0.20 predict this problem right? Yazid Bindar FLUENT 5 March 6, 2003 03:09
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Simulation of Two Phase Fluid Flow Problem Using Fluent 5.0 Mohammad Al-Shannag Main CFD Forum 1 July 16, 1999 11:28
