Guessing the static pressure needed to produce flow rate
Old   June 22, 2009, 12:53
Default Guessing the static pressure needed to produce flow rate
jpo
jpo is on a distinguished road
Dear All,
I have to guess the static pressure at pressure outlet - it has to produce (approximately) my desired mass flow rate.
I know the following:
- the area of the outlet
- the target mass flow rate
- air density can be approximated to be 1.2 kg/m^3
- from above three quantities, I can calculate air velocity through the outlet
Outlet is open to the atmosphere.
My operating pressure is set to zero.
How do I guess the static pressure at the pressure outlet?
jpo is offline   Reply With Quote
Outlet pressure for compressible flow Michelle CFX 12 September 1, 2015 18:38
target flow rate: varying results Ryan FLUENT 3 January 9, 2008 13:54
--------pressure and mass flow rate Mech FLUENT 2 July 17, 2006 23:29
pulsating static pressure around zero at pipe flow David Kim FLUENT 0 May 16, 2006 13:47
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
