CJ
Rep Power: 17 ![]() |
I am using PBS subscrib the job to clusters for fluent cases. But there are always some error feed back I cannot slove. Is there any one who can help me take a look at it? Thanks a lot!
1. Fluent script: rc /data/l/users/testcase/vf_rng/vf_rng.cas solve/initialize/init-flow-statistics solve/iterate 50 wd /data/l/users/8/testcase/vf_rng/vf_rng50.dat exit yes 2. This is the feed back! Thanks a lot! invalid command [init-flow-statistics^M] > Error: eval: unbound variable Error Object: 50^M solve/iterate 50^M Invalid integer. Number of iterations [1] Error: eval: unbound variable Error Object: wd wd Invalid integer. Error: eval: unbound variable Error Object: /data/l/users//testcase/vf_rng/vf_rng50.dat^M /data/l/users/testcase/vf_rng/vf_rng50.dat^M Invalid integer. Number of iterations [1] Error: eval: unbound variable Error Object: exit^M exit^M Invalid integer. Number of iterations [1] Error: eval: unbound variable Error Object: yes^M yes^M Invalid integer. Last edited by solefire; July 31, 2009 at 03:11. |
Rep Power: 0 ![]() |
I guess the line endings in your script is not correct. I'm guessing you are running this in unix platform. Try "dos2unix yourscriptfile" and then try running the script.
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Fluent - license problem. | Marcin | FLUENT | 3 | April 13, 2018 16:33 |
problem with fluent in batch mode | Pat | FLUENT | 2 | February 13, 2003 13:14 |
sequential batch run | jy | FLUENT | 2 | August 2, 2000 11:41 |
Batch File fo Fluent & Fieldview | Oliver | FLUENT | 0 | July 14, 2000 13:12 |
