Adding a function to modify Output variables in Fluent |
October 5, 2020, 08:46 |
vsjay3
Hi All,
I know you can define functions in Fluent for varying input properties of a solid being modelled such as density variation across the solid. But is there a way I can define a function to modify and plot the original output value resulting from a Fluent simulation? For example, say if I simulate the heating of a solid at a certain temperature, the resulting output temperature of the solid at the end of the simulation will be shown as T. But what if I wanted to define a function to take that original output temperature of fluent which is T and further modify it like for example T(new) = 2T + 3, and then finally give the new T(new) as the final output temperature which I can then plot and post process? Basically I want to know if I can define a function in Fluent that could modify the original output value and give the new modified value. Thank you! |
custom field function, fluent, fluent - udf |
[swak4Foam] outputTime in Swak function | immortality | OpenFOAM Community Contributions | 20 | October 6, 2022 12:08 |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
