outlet boundary condition for compressor modeling |
August 6, 2009, 11:07 |
mazda
Rep Power: 16 |
hi friends, i have several questions.
i want to solve a 3D blade of a compressor with LES of FLUENT. boundary condition I useed is "VELOCITY INLET" for inlet . is it correct? for the outlet, which bounadry condition I must use? is "PRESSURE OUTLET" correct? for using "PRESSURE OUTLET", is minimum distance from outlet plane and trailing edge necessary? and how "gauge pressure" set? i am so thankful for your attention. |
August 6, 2009, 11:38 |
Ryan
Rep Power: 16 |
From my knowledge, you should not use pressure outlet with velocity inlet. I believe that you should be using the pressure inlet boundary condition. When using the pressure inlet condition, you would need to define the temperature as well for the compressible flow. I read in the Fluent manual that when using velocity inlet condition, it should be used with the outflow condition and this would be well suited for incompressible flow. I assume you would want your model to incorporate compressibility effects considering you are modeling a compressor, is this correct? Gauge pressure is defined as: p_absolute = p_gauge + p_operating So you should define the gauge pressure accordingly to this equation If this does not help you try looking in the Manual for more information... Sincerely, Ryan |
August 8, 2009, 03:29 |
mazda
Rep Power: 16 |
thanks ruyguy. i am thankful for your attention. a have another question about this. is there any restriction for the distance of outlet plane from trailing edge and distance of inlet plane from leadin edge?
August 8, 2009, 05:55 |
Rep Power: 16 |
For the in-duct compressed flow problems, pressure inlet and pressure outlet is suitable. Anyway others also possible. for example, massflow inlet and pout. But it will be more difficult to reach convergence.
If the problem is to solve airfoil, pressure far field condition is also reasonable. But Vin and Pout is just for compressed flow? Noway.... |
inlet and outlet boundary condition for turbomachinery solution | siamak1424 | OpenFOAM | 2 | August 15, 2009 11:14 |
outlet boundary condition | khalid | FLUENT | 0 | April 3, 2007 15:01 |
Outlet boundary condition | CN | FLUENT | 6 | May 22, 2005 09:37 |
Outlet velocity boundary condition | Jay | FLUENT | 4 | December 15, 2002 08:27 |
outlet Boundary condition | Tol na Deen | CFX | 2 | July 23, 2002 08:49 |
