Dynamic Mesh and Porous Media Modelling
Old   July 29, 2009, 08:34
Default Dynamic Mesh and Porous Media Modelling
Vidya
vidya is on a distinguished road
I am trying to model a screen to filter particulate matter from a slurry. This screen vibrates and the filtering action takes place both due to gravity and vibration of the screen. The screen motion follows an elliptical path 9function of sines and cosines). The screen is modeled as a porous medium using the VOF model.
However, I am just working with the vertical component of motion i.e. the screen just moves vertically up and down. But I cannot get the screen to move the right way because it is getting completely disconnected from the geometry and penetrating into the slurry and air zones (on the top and bottom, respectively). I am not sure if it is due to some error in the geometry construction or defining the center of gravity.
Also, why does the orientation of the axes differ in Gambit and Fluent? I mean, I drew the geometry in Gambit such that x-direction is the horizontal direction and y-direction is vertical. But when the mesh is imported into Fluent, this doesn't seem to be the case and the axes are difefrent. Why does this happen?
Can you please let me know your thoughts? I can send the files for your referral.
Thanks and regards,
Vidya
vidya is offline   Reply With Quote
POROUS MEDIA Sean Cody FLUENT 8 March 6, 2013 10:33
Porous zone+heat generation+tetrahedral mesh Nicolas Ruiz FLUENT 0 July 31, 2008 16:46
Simulation of a flow through porous mesh in fluent G.Vijaya Rama Reddy FLUENT 0 September 14, 2006 00:35
REG POROUS MEDIA HEAT TRANSFER Rashmi Venkat FLUENT 6 June 1, 2006 05:13
pressure drop in porous media Dongying Qian FLUENT 4 January 2, 2004 14:38
