Print contour level in TUI
Old   August 5, 2009, 19:33
Default Print contour level in TUI
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
HI
When we see the filled conoturs and point the left mouse button in the coloured region, Fluent shows in the TUI two values [123, 123] for example does anyone know what these two values indicate?
Shamoon Jamshed is offline   Reply With Quote
Old   August 6, 2009, 02:25
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I guess they are the upper and lower values from your coloured region.
If you also check the scale, the selected colour should be "underlined"
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Importing contour maps into Tecplot jcostex Tecplot 1 May 20, 2009 12:48
Level set vs VOF steve Main CFD Forum 11 September 16, 2008 00:22
Define animate using TUI Zurlugh FLUENT 1 July 24, 2008 08:55
Relaxation factors Vidya Raja FLUENT 7 September 26, 2006 20:00
level set for multi-fluids system? Pei-Ying Hsieh Main CFD Forum 1 July 19, 2000 16:42
