Fluent udf--assigning u-velocity to uds
Old   August 10, 2009, 15:46
Lightbulb Fluent udf--assigning u-velocity to uds
Troy Snyder
tas38 is on a distinguished road
I was working with a Fluent udf that involved assigning the flow primitive, u-velocity, to a uds.
C_UDSI(c,t,0)=C_U(c,t)
However, when I plot the user-defined scalar within Fluent, the value is not close to the theoretical value for u-velocity. Additionally, the plot of of the uds looks does not match the plot of X-velocity.
Has anyone encountered this problem before?
I do not want to continue writing my udf if the assignments to user-defined scalars may not be accurate.
I hooked the udf to a simple test case of couette flow. The visous flow is between a stationary bottom plate and a top plate moving the x-direction at 1 m/s. The distance between the plates is 0.001 meters. Taking a Line Rake of points along the midline of the geometry, X-velocity ranges from 0 at the bottom stationary plate to 1 at the top plate--this is in agreement with theory. User-defined scalar 0, however, ranges from 0.4491 at the bottom plate to 0.5168 at the top plate?
tas38 is offline   Reply With Quote
Old   August 11, 2009, 10:41
Max
coglione is on a distinguished road
Hello Troy
be aware that if you define a UDS Fluent will solve a transport equation for this scalar. Therefore C_UDSI(c,t,0)=C_U(c,t) is only true at the moment this assignment is executed in your udf (which one do you use?) but values will be updated every iteration/timestep performed.
cheers
coglione is offline   Reply With Quote
UDF in Fluent Andrew Fluent UDF and Scheme Programming 5 March 7, 2016 03:38
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 18:29
Pb with simple Fluent UDF example for inlet francois FLUENT 0 October 9, 2008 10:34
Urgent! Help on UDF to set inlet velocity Ray Hong FLUENT 4 December 30, 2005 12:32
