Boundary condition for supesonic nozzle simulation |
March 19, 2008, 15:55 |
Hi all, I am doing 3d simulation of convergence-divergence nozzle with supersonic flow. Mach no. around 2. I am using std K-e model. I would appreciate if someone can suggest me what would be the proper wall conditions for the nozzle. The average thickness of my nozzle is 0.1 inch. I went to couple of research paper, some have used adiabatic wall and some as constant temperature wall. Since this is supersonic flow simulation, I am not sure what to use as wall condition. I will really appreciate any suggestion on this. Thank you in advance. Abhinav
March 19, 2008, 18:56 |
Re: Boundary condition for supesonic nozzle simula
Both wall conditions are right. A adiabatic wall can be maintained at constant temp.
March 19, 2008, 19:28 |
Hi Hirdesh, Thank for replying so quick. What you say adiabatic wall will be good or convective wall with specific heat transfer coefficient will be the good option for me. As flow is supersonic and mtl of nozzle is steel with 0.1 inch thickness.
Once again thank you very much for reply. Abhinav |
March 19, 2008, 20:53 |
Hi, I think solid wall can't be convective. So better to take adiabatic wall.
Hirdesh |
March 26, 2008, 03:31 |
What exactly do u need at the wall are u planning to study the flow properties or the heat transfer across the wall. if your interest is only flow you can have only no slip condition at the wall and leave the default options of wall boundary condition as it is or if u need to study the heat transfer coefficient then u need to bother about it as maintaining the wall at constant temp or adiabatic
it entirely depends on ur problem definiton |
March 28, 2008, 14:06 |
My main aim to analyze flow and in particular shock waves ... So I wanted to keep boundary condition simple still realistic ... What you suggest I should use as Boundary condition, as boundary condition is important for realistic results. Thank you.
September 26, 2009, 04:31 |
tunzaw
Rep Power: 16 |
Dear Abhinav and all
I am also trying to simulate 3d CD nozzle flow. But I am very bad in grid generation. I use GAMBIT for grid generation. If you have any example of 3d CD nozzle grid generation and FLUENT simulation, help me please. I wonder if you make reply to me. my email is tunzawcn@gmail.com |
nozzle boundary condition | Shuo | Main CFD Forum | 4 | September 28, 2007 07:28 |
boundary condition at nozzle exit | Akbar | FLUENT | 1 | June 30, 2005 05:46 |
Boundary condition, UDF, Wave simulation | hm | FLUENT | 0 | August 2, 2004 21:45 |
boundary condition for fan simulation | Mark | Main CFD Forum | 2 | March 31, 2004 11:46 |
2D simulation as boundary condition for 3D problem | Jan De smet | FLUENT | 1 | October 11, 2002 02:02 |
