August 27, 2009, 12:18 |
recompile fluent?
Casey
Rep Power: 16 |
I am having trouble using a UDF to define the frictional viscosity for a simulation. I tried to copy the fluent internal code model, but i am getting a solution that is way off. I have heard of people making changes to values in the .h (header files) in the src folder and then running fluent with the new limits (or definitions). Has anyone ever done this? If so how do you recompile fluent after changing the .h file?
compile fluent .h |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 16:48 |
FLUENT versions ... | Gautam | FLUENT | 3 | November 1, 2007 10:49 |
Run Fluent in batch mode | Shengping LUO | FLUENT | 2 | October 24, 2000 05:42 |
