About Gambit and Parallel Computing
Old   April 3, 2006, 02:23
Default About Gambit and Parallel Computing
yuki
Hi everybody. I have some question about Gambit and Fluent.
1. I want to mesh in Gambit but it spend many time. Does Gambit has parallel mesh generation ?? or There are another program can use parallel mesh generation and can import to Fluent 6.2??
2. I define source term by UDF. I can not run this code in parallel version. Do you have any suggestion for me??
Best regards, Yuki
Old   September 6, 2009, 10:13
Sayros yadgar
syadgar is on a distinguished road
Did you find out how to run gambit in parallel mode? is it possible to do that?
Thanks,
syadgar is offline   Reply With Quote
Old   September 7, 2009, 01:13
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I don't think so
The best way should be to run gambit under linux 64 bit
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
GAMBIT on Parallel Aeor FLUENT 2 November 12, 2007 18:47
Does gambit has parallel mesh ??? yuki FLUENT 0 January 12, 2006 01:36
parallel computing and batch ahmet FLUENT 0 December 20, 2005 14:11
Gambit can be run in parallel? zjuADou FLUENT 1 July 24, 2005 07:33
Gambit in parallel galeazzo FLUENT 3 April 12, 2005 16:47
