Defining Regions and Patching
Old   September 12, 2009, 16:46
Default Defining Regions and Patching
Hoper is on a distinguished road
I am attempting to simulate laminar two-phase flow in a triangular capillary using the computational fluid dynamics code of FLUENT --- it is intended to be an immiscible flow in which the wetting phase displaces the non-wetting phase in a piston-like transport process.
According to observations, the meniscus is supposed to be a cup-like (spherical) interface separating the two phases. The problem I have is that I do not see the two phases whenever I define regions and patch them; I only see one phase in the entire length of the capillary.
I will appreciate every good suggestions.
Note: It is a microscale VOF type flow!
Hoper is offline   Reply With Quote
Old   September 14, 2009, 01:21
-mAx-'s Avatar
Maxime Perelli
if you defined the 2 regions, then you go to initialize, and after (in this order) you set the vof-region with patch.
VOF Patching fluids at an angle? Brian FLUENT 0 October 26, 2005 20:58
