One-way coupling in Eulerian -Eulerian model
Old   October 8, 2009, 00:44
Default One-way coupling in Eulerian -Eulerian model
sm
swati_mohanty is on a distinguished road
I am simulating a 3-D multiphase system (liquid + two solids). I have an external force affecting one of the solid phases and therefore adding a solid momentum source term for this phase. however, I find that the velocity of the other two phases are also getting affected. In the interaction panel, I provide interaction only between the liquid and the solid phases and no interaction between the solid phases. I want only the liquid phase to have affect on the solid and not the solid on the liquid phase. How can I do this in Fluent
swati_mohanty is offline   Reply With Quote
Coupling combustion model and multiphase flow Erika FLUENT 3 May 9, 2015 03:18
VOF in Eulerian model isabel FLUENT 0 January 21, 2009 06:45
Mass and het transfer using eulerian model Pablo FLUENT 0 February 16, 2007 08:36
non-granular diameter Eulerian model jan FLUENT 0 December 8, 2006 10:48
Strain Rate in eulerian model galeazzo FLUENT 0 January 25, 2005 07:52
