Warning: ST_Malloc: out of memory.malloc_storage
Like Tree2Likes
  • 2 Post By ak6g08
Old   October 9, 2009, 10:52
Default Warning: ST_Malloc: out of memory.malloc_storage
Ivan
IvanCFD is on a distinguished road
I am running a 3ddp case, meshed using GAMBIT and then exported to FLUENT.
The number of cells of my grid is 2160000.
Its giving me the following error
[b:60a77ba75e][color=blue:60a77ba75e]Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Z Velocity Gradient, size 92651040, t 2, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Body Force, size 92651040, t 2, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Body Force Corr, size 92651040, t 2, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Mass Flux, size 61298560, t 9, myid 1000000.
Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc f_a1, size 30649280, t 9, myid 1000000.
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error Object: ()[/color:60a77ba75e][/b:60a77ba75e]
My system is a Windows XP 32 bits with 4 GB of RAM, although the Memory Status application of Fluent says that I have got 2004012 KB of physical memory plus 2047724 KB of page memory.
Anyone who have some idea please help me.
Many thanks,
Ivan.
IvanCFD is offline   Reply With Quote
Old   October 9, 2009, 13:24
Akour
ak6g08 is on a distinguished road
hi,
anything over 1 million cells requires a fluent parallel solver. check if your PC has multiple processors, and then issue the command
fluent 3ddp -tx
where x is the number of processors you have. various things change when you run fluent in parallel so i recommend you consult the manual.
otherwise, ule need to get your hands on a cluster!
akour
nasser and amin.z like this.
akour
ak6g08 is offline   Reply With Quote
access_violation, malloc, out of memory, st_malloc
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 06:59
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 19:53
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
