Hi all
I have some confusion regarding Fluent parallel process. If we have a single CPU with quad cores it means we have 4 cores. So do we need a single parallel license for that or for separate licenses (each for each core) Secondly, if I have 8 cores and I give the command fluent 3ddp -t9 it still shows me 9 nodes but technically speaking it should not show that because of physical 8 cores. |
Maxime Perelli
Rep Power: 41 ![]() |
I suppose you need a license per core (need to be confirmed).
Second guess, I assume you can enforce more process on a core
In memory of my friend Hervé: CFD engineer & freerider ![]() |
Matthew
Rep Power: 17 ![]() |
The way I understand it from the documentation is that you need one license for every core. However, I have run it on 8 cores of a cluster with only a 4 seat license, and a process check confirmed that it actually had 8 processes running on 8 different cores.
So you may just have to try it and watch the process tree. |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
4 core & 8 core: same 64bit XP, Xeon, x5570, 2.93GHZ | leeruoyun | CFX | 4 | August 19, 2009 00:47 |
Serial Job Jumping from Core to Core | Will | FLUENT | 2 | August 25, 2008 14:21 |
4 (one core) or 2 (double core) processors? | Gen | CFX | 9 | February 21, 2008 05:48 |
Questions about CPU's: quad core, dual core, etc. | Tim | FLUENT | 0 | February 26, 2007 14:02 |
