Wall jet(please help me urgent)
Old   November 12, 2009, 10:52
Unhappy Wall jet(please help me urgent)
Maryam Amiraftabi
maryam is on a distinguished road
Hello every body,
I want to simulate wall jet with Re=1000 and Velocity= 1m/s ,
now I generated mesh and imported to fluent,
I set all of data in fluent , I use a 2d box with 220mm hieght, 1000mm lenght and 10 mm slot width,
now I want to define boundary condition for it( inlet velocity for slot width, out let pressure for end of surface, no slip for bottom wall) and I don't know what can I do with top wall or free surface, I used pressure inlet and another time, wall specified shear but my simulation was wrong, please help me.
or if you know about jet tutorial please guide me.
thanks
maryam ( m_amiraftabi@yahoo.com)
maryam is offline   Reply With Quote
Old   November 12, 2009, 13:59
bob12 is on a distinguished road
hi
i think that you try simmetry condiction on the top, i know in real there isn't but it resolve the problem.
i hope had a good
bob12 is offline   Reply With Quote
Old   November 12, 2009, 15:34
Default tnx
Maryam Amiraftabi
hi Dear bob12
thank you for your help, but if I use symmetric boundary condition, may be I have another slot on the top of the wall, is this trick possible?
or I should use a taller wall for example 2 meters instead of 0.22 meters!!
I don't know please help.
thank you
Old   November 12, 2009, 17:49
Chris
Chris D is on a distinguished road
Originally Posted by maryam View Post
Hello every body,
thanks
Have you tried pressure outlet for the top boundary?
Chris D is offline   Reply With Quote
Old   November 13, 2009, 01:41
you try the simulation with the condiction that you have but on the top simmetry, if you don't give the command of periodic fluent doesn't another slot becouse for create another slot there is a proper command.
i'm not very pratice with the programm but i hope that is helpful you.
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
URGENT PLEASE- Two-sided wall Mahyar Mohammadian FLUENT 0 July 15, 2008 06:31
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
URGENT WALL MOTION caloggero FLUENT 0 June 11, 2003 10:52
