multiple simulation in FLUENT in Batch mode
Old   October 19, 2010, 08:47
Default multiple simulation in FLUENT in Batch mode
Anonymized_JL1 is on a distinguished road
Its just to help you guys. I was trying to write a journal to run 3 simulations in Que on batch mode on Supercomputer but had been experiencing problem, then Max suggested me to check the journal by writing the command on your Console Window and it worked.
To run FLUENT in the batch mode you can use this journal file. it will run 3 simulations one by one (Transient Case)
file/rcd/Folder Location/File name.cas
grid/check
solve/dual-time-iterate Time Step Iteration/time step
file/wcd File Name
yes
file/rcd/etesh_ncsa/ncsa_simple/ncsa_simple.cas
grid/check
solve/dual-time-iterate 7500 80
file/wcd ncsa_simple
yes
file/rcd/etesh_ncsa/ncsa_sa/ncsa_sa.cas
grid/check
file/wcd ncsa_sa
yes
exit
yes
For Steady case just use solve/iterate 1000 (number of iterations)
Anonymized_JL1 is offline   Reply With Quote
Running FLUENT in batch mode for Windows OS Jake Lee FLUENT 7 June 29, 2016 08:38
Batch issues to get results from a transient simulation aero ANSYS 0 November 10, 2009 06:32
Fluent - batch file - avoiding questions fluentguy FLUENT 1 June 14, 2009 16:57
fluent stops batch mode on error Ralf Schmidt FLUENT 1 March 1, 2008 10:35
Help!! Why I can't run fluent in batch mode? Cindy Jones FLUENT 0 April 8, 2003 23:39
