How to animate the air flow patters inside a cylinder
Old   December 21, 2009, 15:01
Default How to animate the air flow patters inside a cylinder
Vijay
Vijay is on a distinguished road
Hello to everyone. I simulated the air flow patterns in a big cylinder. I don't know how to animate it. Can any one help me. Thanks in Advance.
Vijay is offline   Reply With Quote
Old   December 22, 2009, 20:36
herntan's Avatar
YH Tan
herntan is on a distinguished road
blur question. Post picture of the view u want.
Herntan,
Add Reputation if I am right
herntan is offline   Reply With Quote
Old   December 28, 2009, 19:40
Abhijeet Karnik
akarnik is on a distinguished road
You can do it using Scene animation. Plot the pathlines at increasing steaps. (100, 200, 300 etc) and define each frame as key frame. Once you are done defining key frames, save it as mpeg. The fluent manual has scene animation which explains this (If my memory serves right).
akarnik is offline   Reply With Quote
Old   December 29, 2009, 11:47
Arash
arash_7444 is on a distinguished road
If you want to see steady one, then you need to use Pathline:
Display > pathline> particle ID
but if you want to see unsteady flow animation first go to :
Solve > animate> define > select number of sequence > change Iteration to time step
> again define > now select one of the Display Type
Afterwards, go to Solve> iterate> select number of Type step
finally, when iteration finish, go again to Solve> Animation> Play back > and watch and enjoy
good luck
arash_7444 is offline   Reply With Quote
Problems modeling subsonic engine air inlet with flow separation TWaung CFX 2 March 29, 2009 18:42
Air Flow around a stationary cylinder basilwatson OpenFOAM Running, Solving & CFD 1 May 26, 2008 06:37
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 14:32
axial flow around a cylinder -heat transfer model? Ralf Schmidt Main CFD Forum 1 March 21, 2006 08:54
Flow around a cylinder at subcritical regime. yousef FLUENT 0 March 18, 2006 09:18
