pressure drop equation
Old   July 14, 2009, 17:58
Default pressure drop equation
Gigis is on a distinguished road
Hi everybody,
Does someone know waht is the equation which is used in Fluent for the Pressure droplet??
I am using VOF scheme with air and water, and I calculated the Pressure drop by two different ways, one with an equation from a book talking about micro fluidic system and one other with Fluent . But when I calculate for a simple case (just a square channel) I do not find the same results. So maybe I do not take the same equation as Fluent!
Also, I looked for in the user's guide, but I found nothing.
If someone have a idea, let me know.
Regis
Gigis is offline   Reply With Quote
Old   December 22, 2009, 05:00
Josy
Josyula is on a distinguished road
Originally Posted by Gigis View Post
Hi everybody,
Regis
Hi Regis,
Even I need to find out the equation. If you get to know, kindly please send me a message.
Thanks!
Josyula is offline   Reply With Quote
Total and Static Pressure drop Jaggu FLUENT 3 December 9, 2008 06:03
pressure drop calculation multi-inlet-outlet syst. timmyy FLUENT 1 April 24, 2007 06:03
Pressure Drop - Please Help - Simple Pipe Flow Joe A. FLUENT 2 April 23, 2007 07:50
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 12:30
pressure poisson equation on staggerred grid chandra Main CFD Forum 9 May 5, 2005 06:01
