Question on boussinesq approximation
Old   January 11, 2010, 04:58
Default Question on boussinesq approximation
Panos
panos_metal is on a distinguished road
Hello cfd users
I simulate the air flow in a heater. The wall temperature is approximately 1200 oC. The height is 3 meters and the diameter of the tube is 13 cm. The air flow range from 10 to 220 lit/min. i simulated the procedure in fluent. I would like to use the density of the air in correlation to the air temperature. Can i use the boussinesq approximation? i have read that boussinesq approximation is not appropriate when the temperature differences are large. But this refers to the neighboor cells or to the Toutlet-Tinlet air temperature?
Thank you in advance
panos_metal is offline   Reply With Quote
Old   January 11, 2010, 11:18
Default boussinessq
CFDtoy
CFDtoy is on a distinguished road
Hi there,
Boussinessq goes : rho_modified = rho_ref*(1+beta*deltat). Now, if you have large deltat (Tcell - Treference with which fluid properties are defined)...beta*deltat starts to go close to 1...which means its no longer a small change in rho_ref in a given cell. thats why they indicate u cant use bouss at high Tdiff.
For your case, twall ~ 1200 C - pretty high..yes..but you could definitely try boussinessq approx here. If you see oscillations in the solution, probably you can gain more insight.
/CFDtoy
Visit http://cfdtoy.blogspot.com
Originally Posted by panos_metal View Post
Hello cfd users
CFDtoy is offline   Reply With Quote
boussinesq
InterFoam with boussinesq approximation sinusmontis OpenFOAM Running, Solving & CFD 2 October 25, 2020 12:21
Boussinesq approximation Abdul Aziz Jaafar Main CFD Forum 19 May 3, 2019 11:00
boussinesq approximation jamal FLUENT 2 March 25, 2008 08:57
Boussinesq flows. General question about natural. MW Main CFD Forum 3 September 27, 2007 07:50
Boussinesq approximation again Gabriel Main CFD Forum 3 May 11, 2000 09:24
