Particle volume change
Old   January 23, 2010, 09:48
Default Particle volume change
Panos
panos_metal is on a distinguished road
Hello users
I simulate a metallurgical process on a heater where the phases on the heater are air and (lets say) sand. I decided to use the Discrete phase model to simulate the particles move on the heater as the volume fraction is low(<10-3). After few lab experiments, i saw that the particles density reduce in function with the particles temperature. A the same time the volume of the particles increase. There is no chemical reaction that causes this phenomeno! I have already simulated the air flow in the furnace and i would like to introduce the particles movement. I was thinking of give the density reduction vs temperature by changing the density ( piecewise polynomial) on the particle material properties but im not sure if that would be correct. In my mind, the best solution would be to assume the particle as a bubble that increase its volume vs temperature...
Any ideas please?
I hope i was clear
Panos
panos_metal is offline   Reply With Quote
discrete phase model, fluent, volume change
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
the Eulerian model and the lower volume fraction hx li FLUENT 2 October 27, 2005 06:17
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
