Fluent animations
Old   February 3, 2010, 14:09
Default Fluent animations
Rob
Chappers am I is on a distinguished road
I'm working on the flow around a cylinder in 2D and was wondering if anyone knew how to plot and save the dynamic pressure and velocity around the cylinder so i can make an animation using the images?
Chappers am I is offline   Reply With Quote
Old   February 3, 2010, 21:53
mas
Mas
mas is on a distinguished road
Use Execute Command
eg. /di/sw 1 /di/cont/pressure /di/hc pressure%t.tiff
<Mas>
mas is offline   Reply With Quote
Old   February 4, 2010, 02:43
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
First must define case and data file saving (let's say each timestep).... after that read case and data files in Tecplot... there you can make a good animation
Philipov is offline   Reply With Quote
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Fluent 12.0 is worst then Fluent 6.2 herntan FLUENT 5 December 14, 2009 02:57
Fluent Animations AndyC FLUENT 3 July 13, 2007 09:01
