contour plot help
Old   February 15, 2010, 19:05
Default contour plot help
Jesse
jesse@uconn is on a distinguished road
I am working with internal pipe flows and I am having a problem plotting contours. I created an iso surface with the surface of constant being the grid. When I try and plot the contour I get a colored outline of the figure and when I click on the contour plot the figure gets filed in with the node values. Is there a settingIi can do to show the contour plot filled without holding down left click (filled is checked in the contour menu). Also there are 2.5 million nodes in this and it is on a dual core processor so it should be alright.
Thanks in advance
Jesse
jesse@uconn is offline   Reply With Quote
to set the axes in 3d in contour plot shailendra FLUENT 2 January 15, 2010 01:21
to plot Mach contour using GNUPLOT killtimm Main CFD Forum 2 December 28, 2009 11:15
How to plot vel vector & contour on same plane? student CFX 7 May 12, 2006 08:15
Contour plot in Star-CD Yasir Siemens 0 August 22, 2004 08:01
contour plot of stream function liu FLUENT 6 August 19, 2003 22:30
