NU calculation
Old   April 6, 2010, 03:18
Default NU calculation
m&s
raminj
m&s is on a distinguished road
Hi every body,
I really tried my best to solve my problem ,but unfortunatly I could'nt. the case:
its laminar flow in a pipe with constant wall temperature.. When I get the Nusselt Number from the xyplot/Surface Nusselt Number it can seemed that the Nu begins from a large number(as predicted by theory) and go toward zero at the end of pipe (the theoric value is 3.66).in fact what should I do to reach the Nu=3.66 in constant wall temperature thourgh the length of tube?
Thanks alot
m&s is offline   Reply With Quote
Old   April 7, 2010, 16:06
Kevin
kevpw is on a distinguished road
YOur air temperature may be aproaching your wall pipe temperature. Try increasing the flow.
kevpw is offline   Reply With Quote
Old   April 8, 2010, 04:56
m&s
raminj
but I already tried that. you know let me ask you my question more clear. I want to compute mass weighted average fluid temperatures at step intervals of 10 mm in the axial direction along the tube.
Meanwhile I have attached the data file for more details.
thank you again/
Old   April 8, 2010, 05:13
Default heidar
heidar jafarizadeh
heidar is on a distinguished road
at imlet u must obtaine infinite number. it is a rule
but please atach ur graph and one pic of ur sample.
heidar is offline   Reply With Quote
Propeller calculation toil CFX 15 May 22, 2017 04:06
How to continue calculation after the computer is abruptly shut off? superqtp CFX 5 September 25, 2012 08:53
The calculation efficiency of OpenFOAM chiven OpenFOAM Running, Solving & CFD 4 September 14, 2009 04:44
Warning 097- AB Siemens 6 November 15, 2004 04:41
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 08:19
