April 10, 2010, 16:44 |
Roughness in Turbulent Pipe Flow
milos
Rep Power: 16 |
Hello everyone,
I am trying to model and simulate a pipe with a turbulent flow and investigatng the effect of different levels of wall roughness to the skin friction coefficient, wall shear stress and drag. I am using a k-epsilon model and different values for Ks for example 0.00167m, 0.00304m, 0.00501m. When i analyze the results i obtain by using the XY plot, the plots for skin friction coefficient and wall shear stress are all the same for the 3 cases. can someone tell me what's wrong with my set up? My meshing is finer on the side of the wall. I think the problem might be the meshing being too fine near the wall compared to my roughness. I am using fluent and gambit. Can someone tell me how to correctly mesh or simulate this flow please? i have been looking everywhere in forums and the manuals but dont understand what is wrong with my set up or how to change the meshing properly(if that is the problem). thank you very much in advance for the help! |
April 11, 2010, 05:32 |
milos
Rep Power: 16 |
am i write in saying that i need a coarser mesh to model roughness in a turbulent flow?
and i can only test roughnesses of the height of half my first node right? i mean if i have the first node at a distance of 2cm from my wall (radius being 10cm), i can only test roughnesses to a height of 1cm right? |
April 11, 2010, 05:55 |
Jouke de Baar
Rep Power: 16 |
I assume you have something like this plot? Surface roughness will only have an effect above a certain tresshold value, depending on Re.
LES turbulent pipe flow | panara | OpenFOAM Running, Solving & CFD | 68 | January 26, 2023 11:34 |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 21:25 |
Problems with Cyclic & init. BCs for turbulent (k-eps) pipe flow | florian_krause | OpenFOAM | 3 | December 1, 2012 04:11 |
MapFields turbulent pipe flow | anita | OpenFOAM Pre-Processing | 5 | July 3, 2008 23:29 |
FRICTION FACTOR TURBULENT PIPE and ROUGHNESS | beginner | FLUENT | 1 | July 30, 2007 15:16 |
