April 16, 2010, 23:36 |
Swirling axisymmetric buoyant plume
Ian
Rep Power: 16 |
Hi all,
In modelling a vortex with buoyancy, the axial (vertical) velocity does not seem to be coupled with the buoyant effects despite residual convergence. Under the conditions listed below, the axial temperature difference between the plume and the surroundings reduces to near zero at about 1/3 of the domain height; it is logical that we would observe a decrease in buoyant effects. However, the observed axial velocity remains at 100% of the specified inlet value for the entire span of the domain. A reduction in the temperature differential seems to have no effect on the behaviour of the axial velocity in this regard.
What model would you recommend in order to realise the effects of buoyancy in a swirling plume? Best, Ian |
April 18, 2010, 23:27 |
Ian
Rep Power: 16 |
To follow up, k-omega turbulence models indeed do not account for buoyant effects on the the specific dissipation rate. For this particular case (axisymmetric buoyant jet with swirl), the RNG k-epsilon model with a swirl modification appears to be best suited.
On the standard, RNG and realizable k-epsilon models Ian Last edited by ic7; April 19, 2010 at 00:14. |
buoyancy, k-omega, swirl, turbulence |
oscillating pressure residuals buoyant plume | mabinty | OpenFOAM Running, Solving & CFD | 0 | August 31, 2009 05:31 |
2D swirling flow NOT axisymmetric | Giuki | FLUENT | 3 | May 30, 2009 00:30 |
Buoyant plume source | Iona Evans | CFX | 0 | February 27, 2008 07:29 |
Buoyant Axisymmetric Plumes | imago | OpenFOAM Running, Solving & CFD | 11 | March 29, 2006 06:52 |
turbulent buoyant plume | Theo | FLUENT | 0 | February 13, 2006 09:07 |
