June 15, 2010, 13:10 |
Continuity between interface
Maxime
I try to create a 2D-simulation of a wind turbines which include moving blades. I generate all the grid motion with sliding mesh and UDF Files. Everything works well, but if i run a simulation, i can see that the continuity of pressure and velocity is not taking into account. I try to reduce the time step size and reduce size's meshes but nothing change. To do that i used a laminar model to see in a first time what happens for a low Reynolds number (20 000). I look forward to hearing from you, Titasse |
June 16, 2010, 01:07 |
Maxime Perelli
Rep Power: 41 |
You mean, the flow doesn't seem to go through the interface?
If yes, then did you defined interfaces between your 2 moving regions?
In memory of my friend Hervé: CFD engineer & freerider |
June 16, 2010, 09:23 |
Maxime
The flow go through the interface, but if i plot the velocity magnitude, the pressure, or the streamlines we can see sth completely impossible, in terms of physics. I tried with a simple case, just two fluids with one was rotating and the results is very strange.
June 17, 2010, 01:32 |
Maxime Perelli
Rep Power: 41 |
can you post a picture of what you mean (with mesh overlaying).
The Mesh difference between the interfaces shouldn't be too large because of the extrapolation
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
