can fluent(multiphase model) solve evaporation |
August 26, 2003, 09:16 |
hi, my problem is evaporation of liq. H2 in a closed cylindrical tank that is filled upto some 80% or 60% level,due to application of constant heat flux on the tank. I havent seen any application for this problem in Fluent, even in manual, there is no example. I am presently using mixture model with UDF for source terms of mass and energy into liquid,vapor continuity equn and energy equn. it showing some rate of evaporation as there is decrease in quantity of liq. But i am still suspicious of my modeling, as there is no bench mark problem for this kind. Is there any other possiblity in Fluent or any other package..or the any modification to present problem.
thanks, regards, Prasanth |
August 26, 2003, 10:59 |
Re: can fluent(multiphase model) solve evaporation
Hi!
I'm almolst shure that I've seen something like that on Fluent homepage, but I can't find it now. Anyways I think you're on the right track, concerning, models and udfs that you use. Good luck MATEUS |
August 26, 2003, 11:03 |
I hope too... thanks!!!!
August 27, 2003, 14:35 |
The application you're looking for should be here:
http://www.fluent.com/software/fluen...multiphase.htm |
August 28, 2003, 02:50 |
Hi!
Yes that was it.... MATEUS |
August 29, 2003, 09:08 |
That application is pure boiling...mine is simple evaporation from free surface.any way thanks for ur response.
September 9, 2003, 09:59 |
I observed one defect in my program, even before the liquid is reaching the saturation temperature at the interface there is evaporation taking place. i provided the condition for sat. temp. what could be the reason? prasanth
May 8, 2010, 15:54 |
Mahdi Hosseinali
Rep Power: 18 |
is there a feature for this subject in fluent 6.2? modeling evaporation I mean.
June 15, 2010, 13:54 |
#9 |
teo wei how
Rep Power: 15 |
bro...can u teach me or pass me ur udf file for the evaporation process ? i'm currently doing that as well for my final year project ....my email is weihow_8@hotmail.com i need serious help here >.<
June 16, 2010, 06:27 |
#10 |
Mahdi Hosseinali
Rep Power: 18 |
I'm sorry but as long as I know there is no simple way, for my work it was easier to do several repeatedly calculations than find a solution in fluent.
Can I use turbulent model to solve a laminar flow? | nikhil | FLUENT | 5 | February 1, 2011 10:42 |
Half laminar and turbulent model trying to solve | Andrew Clarke | FLUENT | 5 | May 19, 2008 13:40 |
Mixture model - water droplet + air - EVAPORATION | bohis | FLUENT | 4 | January 25, 2008 11:04 |
Droplet evaporation model (Dukowicz) | student | Main CFD Forum | 0 | January 25, 2007 04:25 |
Seawater evaporation model | Gerardo Trejo | FLUENT | 0 | September 5, 2005 20:33 |
