Gambit meshing help
Old   June 21, 2010, 12:40
Default Gambit meshing help
Matt Lively
mclively1 is on a distinguished road
Hello all, I know this question has been posted many times, but I am having problems meshing a sharp leading edged delta wing in Gambit. I am able to mesh the faces just fine using size functions, but then I try to mesh the volume using tet/hybrid and it keeps telling me "initialization failed; perturb ...." I am sure many of you are familar with this error.Also if it would help, I would be happy to email the .dbs file to you. Should you need it my email is mclively@yahoo.com. Please, any help would be greatly appreciated.
mclively1 is offline   Reply With Quote
Old   June 22, 2010, 01:02
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
apply a size function (meshed option) and set your fine surface mesh as source
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 23, 2010, 17:52
Matt Lively
I actually found an issue with the geometry and replaced it fixing that problem. Now my issue is I am trying to wrap a 3D boundary layer around the delta wing. I am having problems with Gambit creating inverted elements at the sharp leading edge of the wing.
I am given the warning while it is meshing telling me:
"WARN: The interior angle of volume volume.1 along following edges is too large for side type boundary layer, which may generate poor elements: edge.8 and edge.7 ."
How do I get around this? Thanks again for your help.
Old   June 24, 2010, 01:58
-mAx-'s Avatar
Maxime Perelli
post a picture
Old   June 24, 2010, 12:11
Default Pictures
Matt Lively
Here are some pictures of the geometry that I am using. Any advice you could give me would be greatly appreciated. Thank you very much for your help and have a great day.
Or here is the link to the pictures if the above ones do not work:
http://picasaweb.google.com/10817239...ambitPictures#
Old   June 25, 2010, 01:39
-mAx-'s Avatar
Maxime Perelli
try to enable "Wedge Corner shape"
fluent, gambit, meshing
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! lau06165 ANSYS Meshing & Geometry 1 March 22, 2010 01:09
Gambit: too long meshing time! delsolman FLUENT 1 January 29, 2008 19:06
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
Meshing Aircraft with Gambit Ed FLUENT 5 November 9, 2004 05:04
urgent help needed for meshing in GAMBIT chris FLUENT 0 September 5, 2002 09:18
