June 22, 2010, 12:44 |
Turbulent viscosity and shear rate
Rep Power: 16 |
Hi!
I'm wondering about the connection between turbulent viscosity and shear rate. I'm using a non-linear model to define the viscosity of a fiber suspension. When the shear rate is about 200 a turbulent viscosity of 1 Pas should be used. According to the author of the doctoral thesis I've gotten the model from this should correspond to the turbulent viscosity of water. However when I perform simulations with water the turbulent viscosity in the regions where the shear rate is 200 is about 1/10 of 1 Pas. So I wonder if someone knows the reason for this? Is it because my flow is different than his? I thought water would behave in the same way if the shear rate is the same. Cheers! |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 07:18 |
UDF Viscosity Depending on Shear Rate | mannobot | FLUENT | 0 | April 23, 2010 09:46 |
Help - UDF for solid shear viscosity | nbh2801 | FLUENT | 0 | April 21, 2006 07:49 |
shear stress scalar definitions? | Novak Elliott | CFX | 0 | April 6, 2003 01:45 |
