July 1, 2010, 17:25 |
Deforming wall problem
Hi everybody,
in my project there is deforming wall, which is just elongating line, at one end fixed to stationary wall and to a moving wall at another end. if I mesh this deforming edge in gambit with 5 nodes when I run Mesh motion in fluent those 5 nodes on deforming wall wont move, they stay fixed where they are. only the last cell between 4th and 5th node deforms. if I make a very coarse mesh so that deforming edge is meshed with only one cell every thing goes ok. they I made an adaptation on this coarse mesh so that there are 4 nodes on deforming wall, then wall deformed as it should, like a spring, all the nodes moving. but this time mesh on the rest of the geometry was degenerate because adaptation was made on a very coarse mesh and it gave negative volume. it is quad pave mesh. geometry option for deforming wall is faceted. I tried spring, laplace smoothing, with 100 iterations, played with spring factor and boundary relaxation factor. if you know what I am doing wrong or can make any guess on how to solve this problem please help. thank you |
July 2, 2010, 11:29 |
Ive solved this problem if anyone is interested Ill explain how
January 10, 2011, 06:11 |
I will be very intrested to know how...
January 10, 2011, 06:22 |
by default, spring is turned off for quad mesh ! you have to turn it on from text user interface. after turning on dynamic mesh, from text interface:
de/mo/dmc/sp/soas enter then type yes |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
moving wall BC problem | Sourabh | Main CFD Forum | 1 | August 8, 2006 07:47 |
Radiation problem with one wall | bkoh | Siemens | 2 | March 3, 2005 20:21 |
Vibrating / Deforming Wall UDF | Qureshi | FLUENT | 2 | January 16, 2004 04:48 |
Z wall or Deforming Wall | bharath | FLUENT | 0 | October 31, 2003 15:23 |
