Profile Inlet FLUENT
Old   July 6, 2010, 14:06
Default Profile Inlet FLUENT
kingjewel1 is on a distinguished road
Hi there,
I've measured 66 points experimentally across an inlet vent (44X23cm). Does anyone know how they should be set out in the profile file to be read by FLUENT. The user manual doesn't make it clear enough for me.
Thanks guys!
kingjewel1 is offline   Reply With Quote
Old   July 6, 2010, 22:15
Smile why don't you use UDF
Furui Xiong
Furui Xiong is on a distinguished road
Originally Posted by kingjewel1 View Post
Hi there,
Thanks guys!
I guess at each point, the inlet velocity would not be the same. However, Fluent doesn't own the boundary condition to set inlet velocity as a function. So you must define your own inlet profile. UDF seems to be the best and only option. Hope this might help you
Furui Xiong is offline   Reply With Quote
Old   July 7, 2010, 04:13
Yes you're right, 66 different velocities, not representable by an analytical function. Can this still be done in UDF? I have not seen precendents, but FLUENT suggests a profile file... Can you suggest how to do it?
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
inlet analysis using fluent kiran aero FLUENT 0 October 24, 2009 13:26
Inlet Profile with CFX-Pre Fadi Ishak CFX 1 June 10, 2008 07:12
How to give pressure inlet in Fluent Vijayaragavan Main CFD Forum 1 December 17, 2007 09:40
inlet velocity profile in Polyflow srinu FLUENT 0 January 16, 2003 20:25
