how to get value for each node.
Old   January 17, 2006, 02:23
Default how to get value for each node.
Mie
I would like to ask how i can get velocity value for each node (meshing) when i using Fluent 6.1 software.I am created my object using gambit and try to predic velocity value and vortex shedding behind the building/bluff body.I hope u can tech me how to get that value.
Old   January 26, 2006, 06:28
Default Re: how to get value for each node.
Ralf Schmidt
use file->write -> profile
There is a surface that represents the mesh. Usualy it is named "default-interior:1". For every volume in your geometry there is this surface.
Then select the values that should be written (velocity,...) and thats it!
Ralf
Old   January 28, 2006, 09:41
mIe
Thank you very much Ralf.Just one question here.If i want to get all value for every node (for one surface), can i represent it in m.excell.
Second question.Can i put velocity value to each node in my surface when i done my meshing?
Old   January 30, 2006, 02:16
Ralf Schmidt
representing the profile files in excel is possible... but with a lot of work. Fluent prints the values all behind each other, so u must resort them in excel - and that might be impossible for a large number of cells. Someone send me a matlab file, that can read the Fluent profile file, it is attached.
The second question, if there is a possibility to use Fluent valus in gambit?? I don't thing so...
Best wishes Ralf
___________
function [flaeche,vars,werte]=lies_fluent_profil(datei)
% Datei öffnen
fid=fopen(datei,'r');
% alle Flächen
for f=1:inf
% Ende, wenn Dateiende erreicht
if feof(fid)
if length(flaeche)==1
werte=werte{1};
end
fclose(fid);
return
end
% Fläche bestimmen
zeile=fgetl(fid);
a=find(zeile==' ');
flaeche{f,1}=zeile(3:a(1)-1);
% Anzahl der Punkte bestimmen
n=str2num(zeile(a(end)+1:end-1));
for i=1:inf
zeile=fgetl(fid);
if length(zeile)==1
werte{f,1}=sortrows(dat,[1 2 3]);
clear dat,
break,
end
% Namen der Größen bestimmen
if f==1 && length(zeile)>1
vars{i,1}=zeile(2:end);
end
% Werte auslesen
dat(:,i)=fscanf(fid,'%f',n);
zeile=fgetl(fid);
zeile=fgetl(fid);
end end
Old   February 1, 2006, 23:13
Default Value for every single node
mie
Thanks Ralf for the coding..Ralf,can i want put value for each node at my surface,i mean in Fluent. Ralf, if if have any problem,i will email u again..i quiet new in this field. i hope u can tech me...
Old   February 8, 2006, 22:33
Default Stremline problem
mie
hai, I would like to asking u about stremline.So can u tech me how to display the stremline in fluent.I want see structure of vortex behind the bluff body....
Please help me...
Old   July 20, 2010, 17:39
machaae is on a distinguished road
Originally Posted by Ralf Schmidt
;128287
Best wishes Ralf
___________
% Datei öffnen
% alle Flächen
for f=1:inf
if feof(fid)
werte=werte{1};
end
fclose(fid);
return
end
% Fläche bestimmen
zeile=fgetl(fid);
a=find(zeile==' ');
for i=1:inf
zeile=fgetl(fid);
if length(zeile)==1
clear dat,
break,
end
end
% Werte auslesen
zeile=fgetl(fid);
zeile=fgetl(fid);
end end
Hi Ralf,
I was reading this post because I need to plot contours of fluent data using matlab. This piece of code works well, I tried, but it just open the data file and I dont know waht do after. Do you know how to include a contours function? or what to do after reading the profile file and then to plot something?
thanks a lot!
machaae is offline   Reply With Quote
node values vs. no node values in fluent user0314 FLUENT 4 June 30, 2019 04:14
Export node number and coordinates kezman CFX 2 November 7, 2015 15:45
Accessing node values using a UDF Nico FLUENT 2 December 20, 2007 02:50
License server not visible from master node Charles FLUENT 0 October 30, 2007 17:48
how can i list node temperatur by node location Ali Doustdar FLUENT 2 July 12, 2007 23:48
