Two-phase flow in a Y-shaped pipe
Old   August 10, 2010, 05:46
Default Two-phase flow in a Y-shaped pipe
PP
pandaba is on a distinguished road
Pneumatic conveying of micro-glass beads in a Y - shaped pipe occurs. I am using Fluent software to simulate the flow.
Given Data:
Gas volume flow ratio : 0.0097 m3/s
Inner diameter of pipe : 32 mm
Solids loading ratio : 81320
Particle diameter : 2 mm
Particle density : 2510 kg/m3
Bulk density : 1386 kg/m3
Sphericity : 0.92
How to find the inlet velocity for each phase , void fraction , flow rate weighting at out flow so that I can use the data for simulation.
Thanks in advance........
Regards
Pandab Patro
pandaba is offline   Reply With Quote
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
pulsating static pressure around zero at pipe flow David Kim FLUENT 0 May 16, 2006 13:47
outlet boudary condition for a flow in the pipe Atit CFX 2 November 9, 2004 17:43
gas solid pipe flow tahar Phoenics 6 November 3, 2003 12:03
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
