DPM Diameter querry
Old   August 16, 2010, 22:00
Default DPM Diameter querry
Mohsin Mukhtar
Mohsin is on a distinguished road
I am using DPM surface injection from inlet whose sides are 0.82*0.89 m. But when i inject particles of 10 m diameter still i get the resullt at the outlet. why is it so??? How can a particle enter into a duct having bigger dimensions than the duct? Aren't I supposed to get an error??
Your urgent response will be highly appreciated.
Mohsin
Mohsin is offline   Reply With Quote
Old   August 16, 2010, 22:37
xrs333
xrs333 is on a distinguished road
DPM model is a Euler-Lagrangian multiphase flow model, that is, the discrete phase is considered as particles no matter how big it is, only the trajectory of the centroid is cumputed.
xrs333 is offline   Reply With Quote
Old   August 16, 2010, 22:43
Mohsin Mukhtar
Thanks for your reply
As far as i know in the langrangian method the particles are tracked while in Eulerian method fixed point is taken and particles are not followed.
Dpm uses Langrangian formulation but How can a trajectory be calculated if the diameter of the particle is larger than the duct in which it is moving? could u please elaborate.
Old   August 16, 2010, 23:00
xrs333
In real world it is impossible for the diameter of a particle larger than the duct. So, in the computer, if you build a computation model like that, the mistake is brought about by you, not by the computer or the DPM model. You built a wrong model with a improper method.
Old   August 16, 2010, 23:04
Mohsin Mukhtar
ok so i will assign the diameters according to the streams I m sending in. for exapmple for group injection of 5 streams in a duct of 5m, I will assign a diameter starting to end point as 0.1 so that each particle stream has 0.1 diameter and it should remian in the domain. otherwise if i assign a diameter of 0.2 fluent will still calualte it but as u mentioned it would contradict with the real world problem and would have errors.
If i m wrong please let me know. Thanks for your time.
DPM diameter mass distribution Wouter FLUENT 5 May 23, 2019 02:18
Importance of Hydraulic Diameter Value for Compressible Flow RyGuy FLUENT 0 August 6, 2009 10:58
DPM - do the particles affect the liquid? Nikhil Dani FLUENT 0 January 1, 2009 11:58
The minimum diameter of second phase in the DPM Fluenter FLUENT 2 August 15, 2004 06:46
DPM - setting the density and diameter Christian Svensson FLUENT 0 February 14, 2003 13:44
