What is the relation between Static temperature And total temperature? |
August 16, 2010, 01:54 |
Subhankar
Rep Power: 15 |
Hi all,
what is the relation between Static Temperature and total temperature? Thanks. |
August 18, 2010, 14:46 |
Troy Snyder
Rep Power: 18 |
The total or stagnation temperature is the temperature that would exist if a fluid was brought to rest isentropcially. In other words, the total temperature includes the static temperature and an additional component due to the velocity of the fluid. For a perfect gas, the total temperature may be expressed as T_total = T_static + 1/2 * V^2 / (cp), where u is velocity magnitude and cp is specific heat.
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 06:36 |
static temperature more than total temperature ?? | mahesh | FLUENT | 4 | May 18, 2016 06:09 |
Total temperature and static temperature | rogbrito | CFX | 1 | June 21, 2009 18:37 |
Static and Total Temperature | Tomislav | FLUENT | 4 | December 4, 2006 04:59 |
The static temperature is higher than total temp | devy | FLUENT | 0 | March 27, 2003 20:16 |
