How to save images of contour plots during parallel job
Like Tree1Likes
  • 1 Post By Neil11
Old   September 2, 2010, 03:32
Default How to save images of contour plots during parallel job
Francois
Neil11 is on a distinguished road
I use Fluent 6.3 and I would like to create and save images of contour plots automatically, when my job is running in parallel on a cluster. The images will then be used to create an animation of the unsteady flow.
The problem is that the job is running without graphic interface. So I cannot use basic commands as display, hardcopy, etc.
I know that another solution consists of saving a data file (.dat) each time I want to save an image and then, post processing the data (for space disk reasons). But this solution does not suit me because it takes too much hard disk space and time.
Have you any suggestions?
Thx in advance
Neil11 is offline   Reply With Quote
Old   September 8, 2010, 13:15
Lawrence
Lawrence is on a distinguished road
I have the same problem with you...
I am using Fluent 12.1..
Let's wait for others' suggestions..
Lawrence is offline   Reply With Quote
Old   September 8, 2010, 17:06
Francois
Hi Lawrence,
I found the solution (for Fluent 6.3)
Before, i used this command to run my job:
"Fluent 3d -g ... journal.jou
The "-g" disables all graphic tools.
Now, I use this command to run my job and it works...
"Fluent 3d -gu -driver x11 ... journal.jou"
With "-gu", the GUI is disables but not the graphics...
So, you can use, in your journal file, the commands "display", "hardcopy",... to save images. Or you can also create a macro if you don't want to modify your journal file.
bye bye
villager likes this.
Old   September 21, 2010, 17:26
Lawrence
Thanks very much.
You are right...
Old   September 21, 2010, 21:10
pranab_jha's Avatar
Pranab N Jha
pranab_jha is on a distinguished road
Thanks Francois... I too had the same question.
pranab_jha is offline   Reply With Quote
Old   September 23, 2010, 19:06
pranab_jha's Avatar
Pranab N Jha
Hi Francois,
I tried what you suggested, but did not get the result. I have posted another thread. Pls take a look and suggest.:
http://www.cfd-online.com/Forums/flu...-tracking.html
images, job, parallel, save
Partitioning problems in the parallel job Neo FLUENT 5 January 26, 2021 10:10
CFX Contour Plots Troubleshooting derz CFX 7 November 21, 2010 10:08
vector plots and contour plots do not match swati_mohanty FLUENT 1 August 26, 2010 05:53
drawing of contour plots chinthakindi Main CFD Forum 1 April 27, 2004 04:33
Local surface contour line plots Nandu FLUENT 0 November 9, 2003 23:26
