implement a source term!!
Old   October 4, 2010, 09:47
Default implement a source term!!
stage81 is on a distinguished road
My goal is to implement a source term (e.g: energy) in a defined area of my field of computing, I have a simple 2D configudation (100 mesh along the X axis and 100 mesh along the Y axis) and I want to inject a source term (ie: source = 10000W/m3) in a grid of coordinates (X =50 and Y = 50) and I can not specify in my UDF cell in which I would inject my source term..anyone can help me
Écouter
Lire phonétiquement
stage81 is offline   Reply With Quote
Old   October 4, 2010, 10:59
anonym
Laci is on a distinguished road
Écouter
Lire phonétiquement
I would create another plane just in the middle of your area. Hence, for this small area you can apply the source term. (I've never tried in 2D so far, but in 3D it works that way.)
Laci is offline   Reply With Quote
Old   October 4, 2010, 11:44
Thanks for your help,
but I think it should not market, because the goal is to inject the source terms in several mesh (hundreds of cells)..
normally i want use C_CENTROID(x,c,t) ... but I dont know how to define the coordinates of my area in my UDF
Old   October 4, 2010, 11:47
in my UDF (DEFINE_SOURCE (energy_source, c, t, ..) how I will define the coordinates of my cell (X=50, Y=50) ?Écouter
Lire phonétiquement
Old   October 7, 2010, 07:50
Brian
General_Gee is on a distinguished road
Hiya,
I think if I understand you correctly, you want to add a source term but only in a certain area of your domain.
You can access the cell centre using C_CENTROID(x,c,t), see
http://my.fit.edu/itresources/manual...udf/node90.htm
this will give you P (x,y,z). Then if this point is inside the area you want the source to be active you can define your source term, if not set the source term to zero.
Hope this helps
General_Gee is offline   Reply With Quote
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
How to implement source term? Amit Gupta Phoenics 4 May 11, 2006 08:07
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 12:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
